Re: 1997 Mercruiser 3.0LX - Regal 176 - Temp gauge not working
Ayuh,.... Welcome Aboard,.. The gauge needs to see 12v, at it's (+) terminal,...
If so, unhook the wire on the sender, 'n ground it out, the gauge should Peg, Full Hot,...
If it don't, check for a solid Ground at the t-stat housin',...
If there's solid Ground, replace the sender,...
The use of thread Tape on the sender, won't allow it to work, No ground,...
If the T-stat was changed, 'n a gasket, without the brass rivet was used, again, No ground,...
