I have a 1996 StarCraft 2010 with the 5.7L Mercruiser/Alpha One drive. I was investigating a lower unit leak this weekend and can't find the exact spot where it is leaking. I followed the line from the reservoir to the transom fitting and found no signs of leaking. It appears that the oil is leaking below the through hull fitting. I have not pulled the drive yet (no experience with this) and wanted to see if anyone else has had this problem? I purchased the boat last June, and in late August I discovered the leak. The previous owner had the gimbel bearing and u-joints replaced the previous fall. I have been looking for as much information on the what to do as I can find, but haven't been able to find a similar situation. I am more than capable of doing the work but I do not want to dive in with out a basic plan of attack first. Does anyone have any suggestions on where the leak may be coming from? I believe the through hull fitting is the brass fitting and not plastic but I'm not positive. Any thoughts or direction to another post would be great. Thanks
