boozer1966
- May 7, 2012
- 125
1984 Mercruiser 140, serial no. 6873947, Alpha MR
I think the shift interrupt switch may be failing and cause an interruption in ignition when the boat warms up. Is there a good way to test the switch? The boat runs well on the water for about an hour an then develops a miss that I cannot for the life of me source. I switched to a Pertronix ignition system thinking that would cure it, including 12v coil. It did not. Plugs and wires are new. I cleaned the switch this weekend as best as I could, and it performed ok for about two hours before developing the same problem. I know, progress, not perfection. I can't replicate the same behavior on the muffs in the driveway.
Can the switch interrupt switch be cleaned/tested?
Can I purchase the switch by itself? (which I can't seem to find online)
Or do I have to buy the entire plate assembly? (which is pretty expensive)
Many thanks in advance for your responses.
