I have an 88 Chris Craft 290 Classic w/twin 4.3 Mercruisers Alpha One Gen One. Both drives are right rotation. I've had no issues with these drives. I noticed more play in the starboard prop shaft (about 3/8") than the port (about 1/16") . I tore the drives down and replaced all oil seals and o rings. Pressure tested both drives while turning prop, held 15 lbs with no issues. Before I put these drives back on the boat I was hoping somebody out there might know if that's within spec. Thank you in advance for any feedback.
