Re: 1970 mercruiser hard steering to the left
Everything above is correct. But to add, it's always going to be harder to turn to the right, your fighting the inertia of engine rotation. All mercruiser engines are left hand rotation engine. When turning left, your going with the rotating mass that is your crankshaft and flywheel, and that gives you a push in that direction. But when going to the right, your going against that rotating mass, which means you have to fight it. On older boats, with older steering systems, and especially on the straight 6's, the effect is more pronounced.
