Good morning,
I have a Mercruiser 350 MPI, 2005. I have always ran it without the termostat, I am in Venezuela, so the water is pretty warm. The temp gauge never moved neither a bit. But since some months ago, while running at 3000 to 4000 RPM the temp begun to rise a bit every time I ride the boat. So far, running at 4000 RPM, the temp rises up to 165?, then when I slow down the temp goes down. I have already changed the elbows and the manifolds are OK. I inspected the hoses and they are OK. I found some pieces of an old impeller in the check valve but I removed them. The impeller looks OK. I have not inspected the circulating pump nor the ways were the water goes inside the engine. But I think even when the water cannot circulate well through the engine, it can be hot but the temp sender should be fresh because the water coming from the seawater pump goes directly to the termostat housing refreshing it.
The engine is still rising its temp at 3000 to 4000 RPM. So please somebody can advise me were to look to troubleshoot? Can the problem be the circulating pump or some obstruction inside the engine?
Thanks in advance for your help.
