Hello all, new to the forum. I have a 1990 3.0l Bayliner capri with a Alpha 1. In 2010 I had the carb rebuilt and the seals, water pump, and various other things replaced and then got deployed. The boat stayed in the garage and when i got back, i drained all the fuel from the tank and put fresh in. It started right up and then took it out to the lake. for about an hour, It ran fantastic, better then ever....
This is where the fairytale ended, because all the sudden it bogged down at full throttle, and would not go above idle. We had to troll slowly from the middle of the lake (45 min) and it ran (at very slow speed) all the way back.
so i have taken out the fuel filter and it was the original stone kind from 1990! cleaned that out and put a new felt/AL one in the carter style mech.pump.
My question is, does this sound like a fuel pump issue? should i just replace the pump? (got a new Mallory pump) or do you think it has a less prosaic problem like a clogged carb? Hate to rebuild a carb that has only an hour of runtime from the last.
