boozer1966
- May 7, 2012
- 125
1984 Mercruiser 140, Alpha MR drive, serial no. 6853440 - I have been chasing an electrical problem for about a year now and am at my wits end. It is not a fuel problem.
Symptoms are as follows: Boat starts and runs great for 30-45 minutes, then develops a miss. Miss can be made worse by applying any electrical load, for example, trim motor, blower bilge, etc. Engine will eventually stop running and after a cooling off period will restart and run erratically. I took he boat out yesterday, thinking that I had found the likely problem - some corrosion in the canon plug. Same experience - 30-45 minutes of running well, then problems. This time, I touched the coil, and it was clearly too hot.
Voltage readings to the coil are as follows:
Ignition off - 0 volts
Ignition on, but engine not running - 7.5 volts
Ignition starting - 12+ volts
Ignition on, and engine running - 11+ volts
Can a resistor wire go bad? That's what it seems like is happening? All voltage readings seems to be within spec except for 11+ volts to the coil when the engine is running.
A) Is this making my coil overheat when the engine is running?
B) What do I do about it?
Thanks in advance for any responses.
