Pink Floyd
- Feb 16, 2014
- 25
Hello gentlemen,
This is my first post so please go gentle with me. I recently purchased a 1982 19ft bow rider with a Mercruiser 470, 224ci., inline 4 cyl., 170hp, engine (serial # 6038011). I'm not sure it matters but this has a Alpha One Outdrive (serial # 5999024). I have been battling out with this thing for two weeks now. Here's where I'm at in bullet statements for your ease
I have replaced with new the following:
1. Spark plugs (RBL-9Y / gapped to .035)
2. Spark plug wires (connectors greased with diode lube)
3. Distributor cap
4. Rotor
5. Breaker point manually gapped to .022" with feeler gauge. I am waiting on the delivery of my new "Dwell Meter" and plan on precisely setting the dwell angle upon its arrival.
6. Added a "missing" condenser? <---I'm not sure why the old condenser wasn't inside the distributor, but it just wasn't there???
7. I have checked and rechecked the resistance as well as the voltage coming out of the coil. Voltage out with ignition key turned to the "on" position is 11.50v. Resistance on primary and secondary coils were all well within manufacturers specs.
8. I have lined up TDC with the #1 point and rotor inside the distributor as close as possible. I have even manually turned the distributor slowly while my wife turned the ignition on, in an attempt to get the engine to fire up.
9. All cylinders have acceptable compressions: 130, 130, 135, 135 (manufacturer compression pressure 150psi, not bad for a 32 year old engine)
10. I have a timing light ready to go, but I need the engine to run first.
NOTE: The previous owner was a office mechanic, meaning he sat in a office all day and came home to "play" with this boat. Needless to say when I bought it, the spark plug wires were rearranged in correctly, the distributor rotor didn't point to the #1 spark plug when set to TDC, the condenser in the distributor is missing, the spark plug wires were mangled from being put on and off with pliers, distributor cap was worn out, the breaker points were corroded...etc.
11. The engine turns over strong, the fuel system is fine, however:
THE SPARK PLUGS AREN'T FIRING????
This thing is starting to make me feel stupid....Obviously, this is my first experience with a coil/distributor system.
My questions to everyone:
1. What am I missing or where do I go from here?
2. How can I check the breaker point is getting electricity?
3. How can I check the inside of the distributor/rotor is firing?
Or am I completely lost and in the wrong direction????
3. Distributor cap
4. Rotor
