Re: Is a little corrosion normal?
The anode type depends on the water you boat in. In his situation magnesium is recommended.
Mercury and Johnson/Evinrude/OMC started selling the aluminum anodes in the early 1990?s. Other manufacturers are switching to aluminum too.
http://www.performancemetals.com/images/anodes/ABYCrec.jpg
And
WHAT?S ALL THIS ABOUT ALUMINUM SACRIFICIAL ANODES
www.martyranodes.com/content/martyr-resources/Aluminum Anodes.pdf
Another point to consider in the choice is the
type of water
in which the boat will be used.
This can range from salt to
brackish to pure fresh water.
Some Hints
Don?t Mix Anode Types
. If you install different anode materials
like zinc and aluminum, the more active anode (aluminum) will
spend part of its effort protecting the less active metal (zinc). This
will reduce the overall protection that you are getting. A classic
mistake is adding a zinc transom anode to a Sterndrive equipped
with aluminum anodes. Transom anodes are connected through the
bonding system so make sure you install aluminum replacements.
Zinc in Freshwater
: In freshwater zinc can form a coating.
This quickly insulates the anode and stops it from working.
You may think your zinc anodes are lasting a long time when
in fact they have simply stopped working - stopped
protecting!
Keep an eye on your anodes
. When they get to half their original
size replace them. If you leave them any longer there may not be
enough surface area on the anode to deliver the protective current
you are looking for. Judging when to change your anodes can be
difficult!
Magnesium in Salt or Brackish water
: Magnesium is so
active that in salt water it can
disappear very quickly. If used
on an aluminum Sterndrive or
outboard motor it can be
positively dangerous. Aluminum
is ?amphoteric?, which just
means that you can ?overprotect? it. If you take your boat
down river to the ocean with
magnesium anodes you will
probably have a catastrophe on your hands. The
overprotection causes hydrogen
bubbles to form under the
paint on the drive resulting in the paint being blown off! You
also need to be careful about putting magnesium anodes on
an aluminum-hulled boat since
the same thing can happen.
Your freshwater may not be so fresh either. Acid rain and
general pollution can cause the water to be much more
conductive resulting in
the same problems.
Performance Metals has made life simple for the boat owner and
introduced the patented
Red Spot Wear Indicator
anode.
Performance Metals? range of aluminum alloy anodes have a Red
Spot plastic indicator that appears on the surface when it is time to
change.
Don?t forget - it?s better to spend a little on
replacing your anodes on
a regular basis than
the thousands you might incur buying new
propeller shafts or a new Sterndrive lower unit!
Aluminum - The Final Winner!
In our opinion the best all-round anode material is aluminum.
Consider these points !
Aluminum anodes are more active than zinc and are
accepted by the major Sterndrive manufacturers as
the best material to use.
Aluminum anodes are not so active that they are
dangerous in salt or brackish water as are
magnesium anodes.
Aluminum anodes will last
longer because of their
increased current capacity.
Aluminum is the only anode material that can be
used safely in all types of water.
Aluminum anodes are 2 ? times lighter than zinc
making them much easier to carry home from the
store!
Aluminum is a much better alternative than zinc as
far as the environment is concerned, since it is not
considered a pollutant.
