Re: 1989 4.3 litre v6 vortec mercruiser 4 stroke using lost of oil
hi thanks for all your help. the boat is a 1989 Sea Ray Cuddy cabin, spark plug dropped through the piston at WOT A few years back, bought a second hand V6 Vortec 175 HP and married the two motors together new power heads pistons rings lower unit, gearbox, thermostat and gear linkages,had an electric fuel pump put in we had trouble with cold start, and the mechanic took out the valve from he fuel line to the carb thinking that was the problem but now the fuel drains back into the tank so the fuel pump pumps it back in to the carb, complete rebuild basically, newish spark plugs, i thought it must be leaking to but the motor is clean and so it the bottom of the hull were the billlige pump is so im sure its not leaking we use Caltex Havoline Synthetic Blend SN 10W-40 4L
• Havoline with Deposit Shield • Synthetic blend • SAE 10W-40 API SN oil, dads not concerned about it saying that ist doing alot of work and its normall for it to use alot of oil doing alot of work, but im not convinced
