Hello all, I have a mercruiser 165 hp 1974 and have been working on the engine for a while now. I took the head off to replace the gasket, replaced the head and adjusted the valves (to the best of my knowledge) according to the manual. So had it out in the water to test it out and it idled good. once I accelerated it would cut out and backfire. seems like the valves are knocking a bit too but I checked them and they seem snug. I did have to take out the distributor and fix the advance weight because they were rusted. Prior to that I had no advance on the timing. After I ran the engine after fixing the distributor, I put the timing light on and noticed the timing mark way behind the timing like 30 to 40 deg instead of 8.
I am assuming that i may be one sprocket off. could this explain the problem with the backfire and poor acceleration? It was doing the same thing with the backfire and poor acceleration before I fixed the distributor.
If someone has any ideas please let me know.
HAPPY NEW YEAR!!!!
HAPPY NEW YEAR!!!!
