Re: mercruiser 898 305 no spark
[[ did you ever find out why no spark ?? I have the same problem same motor ..had to e towed in yesterday !! Thank you ,joe g.thanks chris, i have removed the tacho and shift interrupt switch leaving only the wire going to the points with no spark.
I will try the grounding of the coil tonight, haven't tried that yet.
I was thinking the breaker plate grounding could be an issue too, how is it supposed to be grounded? I dont have any wires from the distributor other than than the ground for the condeser / points. I was assuming the breaker plate just grounded to the distributor wich in turn grounds to the engine block.
