captainnate
- Apr 19, 2011
- 190
I have been using my Starcraft Nova with a mercruiser 120 a little late in the season in Michigan. To protect the block from freezing and cracking I have been draining the water each time. Somewhere along the line the block drain plug got stripped. So I bought a new one and put it in today. Sure enough that one is stripped after one use. Do I need to tap the drain hole? Can I use the same size? This is the part on ebay:
Mercruiser Quicksilver Brass Plug 22 36382 | eBay
Thanks,
Nathan
Thanks,
Nathan
