I have a 2008 Tahoe 196 with a 4.3 V6 in it. It seemed to run fine all summer then the second to last time out I would put it full throttle and it would only go to 3400 rpm. I could back off completely then full throttle again it would be ok and get to 4600-4800 WOT. The last time I took it out it would not go above 3400 at all. It wouldn't even plane out. Took it to the boat mechanic and he is saying the timing is off. Is this possible without anyone ever being inside of the engine? Also it just seems weird because it ran fine all summer except for the last 2 runs. I am running a 21 prop. Right now I have it winterized and they want to take it out to get the timing right in the spring. I am just not convinced it is a timing issue. Thanks in advance for the help
Chris
Chris
