My engine cover has thunderbird ***** something on it, however the label is worn off. I have the procedures from the mercruiser manuals for a thunderbird iv and v, however when I try grounding the purple/white wire nothing changes. (In accordance with the Merc Technical Manual - perhaps incorrect wire) mine is on the right side mid intake area (looking from behind) around the stern drive res.
Engine is on a test stand.
I have pulled up the mercruiser website and parts manual and looked for the part numbers to see which is installed, but so far haven't figured it out. I have looked at the ecm and ignition module for any numbers or stamping -
BTCU 16184069 and 861253-1 5.7 ALPHA
Both are mounted on the Left Riser, nothing stated on the Distributor
I believe its an Thunderbird V due to the purple - white wire.
I have tried both ways wondering if my ecm is damaged. engine runs very rough at idle, my cover says to set timing to 10 btdc, the mercruiser manual says 8 btdc. Either is a moot point since timing advance is continuing to run.
Need to set timing to check if carb needs rebuilt. Knock sensor is hooked up and will idle around 700 but checking timing because the advance is still working sets timing to 0deg. When i ground the purple/white set to 10 btdc i can tell advance is still moving it around, and eng tries to stall, 0 with advance seems best, but i need to set baseline, drop it into the boat to break it in.
1999 Sea Ray 210 SunDeck
my engine sn# 0L091309
Fresh rebuilt long block from machine shop, previous engine cold busted and Im replacing it, and restoring this boat - winter project
heads casting# 0259906
engine casting # 1024388c
.030 over and flat top pistons.
compression @ 180psi
Thanks for any help,
If you need more information please ask.
