Jeremylong
- Nov 15, 2013
- 3
Hi to all, new to this forum and looking for an answer to a problem with power steering on Merc 4.3 Alpha 1 Gen 2 but with Bravo actuator. Boat is new to me and has not seen water for last 8 Months, just done full service on engine, new impeller on O/D and rewire. 1st time on water yesterday found Steering stiff in both directions, needs 2 hands. Fluid level OK no leaks etc. Read manual but haven't got a pressure gauge to test system or pump pressure. Taken boat to dealer today for repair. Read a few posts on here and discovered that I may have caused the problem by cable tying a flexible conduit to the steering cable near to the actuator restricting its movement? Also I read about the "flats" on the cable sleeve on the actuator had to be in a certain position, this bit I don't understand?
