Hi,
I have a 1989 Ebko ski Boat with a 1989 mercruiser 4.3. The other day i turned on the boat to warm up so i could winterize it and it ran with water for about 8 minutes.I shut it off with nothing abnormal happening. I changed the oil and when i went to restart it to check the oil pressure and run the antifreeze through it, the key turned the motor but if i turned it all the way to the right it stopped turning. When it would turn i would get no spark.Also the gauges dont turn on annymore. Anything you can think of will be helpful.
Thanks
Thanks
