copierkat
- Nov 29, 2012
- 36
Hi all. Wanted to make sure no water in heat exchanger on my 83 Celebrity boat with 470 Mercruiser cause I am in Minnesota, and it's starting to get cold out! Went to examine heat exchanger and noticed bolt in bow end of exchanger, but no cap. I just bought this boat last winter, had it on muffs once this spring, (noticed bunch of water inside hull after starting, now I know why). Can I buy just the end cap for bow side of heat exchanger? Where would I look for a part such as this? Why would previous owner leave that off? Took bolt out of stern side of exchanger, but could not get end cap off. Also, drain plug for seawater drain would not budge. Loosened plug on exchanger for antifreeze with no problem. Did not want to snap other one off so left it. Might spray with PB Blaster. Do I need to worry about water freezing inside exchanger? Anything else I should be draining? Thanks for any suggestions. Dave
