Sangster21
- Mar 15, 2012
- 130
I have just re installed a fresh rebuilt I6 250cu in mercruiser with MC 1 drive, vintage 1976. Got it timed and idle adjustment with a small hitch on the way. We were working on the idle adjustment, when we manually opened the throttle, it got stuck in an open position ( may not have been wide open) and raced the engine. I shut the ign. off quickly and sorted out the throttle linkage, turn out I had the idle cam installed incorrectly and caused the throttle to jam. We were on the muffs at the time. Went to sea trial today and engine ran hot... the thermostat opened, temp dropped than quickly started to to rise. I shut it off. The engine has a San Juan engineering cooling system, with engine coolant circulating through block and the manifold. Sea water goes from leg to heat exchanger and on to cool exhaust elbow and out. Any way, I felt the hose from the transom and it was hot!!?? What the hell? I pulled hose from transom plate (from leg) to heat exchanger and turned over engine to check for sea water flow..... there was exhaust gas and no water!! I am thinking the high throttle toasted my leg water pump impeller when it was on the muffs. Any one have some thoughts for me? The boat is on trailer, so relatively easy to drain gear oil and puller lower off to inspect the water pump.
Alan
Alan
