gwgautney
- Aug 28, 2013
- 283
Took boat out today for first time since I started working on it. First little while it ran fine opened up good. adjusted idle a little bit. was running later and when its under a load you have to ease it up or it will cut out. If you put it in neutral and give it the throttle it is fine it will rev up as much as you want it to. Once you put it in gear though if you give it throttle to fast it will be almost like you cut fuel off. I got home and put it on the muffs and it does the same thing. Is this a shift adjustment issue? If not what could it be?? Thanks
Its not like interuppter switch is kicking in its more like not getting the fuel unless its cutting it almost off I dont know
