Re: electrinic ignition 488 merc
Wait a minute, if you have an alternator, you do not need the water cooled regulator. Your alternator has a built in regulator. The old regulator need not be replaced. If the two yellow stator wires are still attached, removed them, tape the ends and tuck them out of the way.
I think I have my answer, it's a water cooled voltage regulator. My next question is other than replacing the regulator and inspecting and replacing the water impeller what elce should I do. What would cause the regulator to melt like that, stator maybe?
