Mini hog
- Oct 19, 2013
- 29
My Mercruiser 5.7 with alpha gen 2 outdrive has a knocking/clicking noise that I have a really hard time to get rid of. Gimbal bearing and u-joints has been replaced but it has not solved the issue. Outdrive/engine is aligned. Engine mounts looks good.
The noise increases as I turn the steering sharp. Going straight forward there is no noise. Two mechanics has inspected the boat and listen to the noise, no one of them could tell me what is causing the noise. I also sent a question to a mechanic via his webpage and the only idea he got was to replace the coupler.
Before I pull the engine, what do you think, could it be the coupler (I assume the noise could come from worn splines)?
This has been the third season with this noise. But when I re-mount the outdrive (lower house) this spring there where no noise the first 15-20 minutes. I used a lot of grease on the drive shaft. Maybe that terminated the noise for a short while??
All ideas are welcome!
Rgds from Sweden
Rgds from Sweden
