Grizzy1967
- Apr 10, 2013
- 25
Hello,
I have a 4.3 mercusier that i have owned since march of this year. Boat ran great all summer long, like a sewing machine. i went to winterize it sunday and unscrewed the oil flter and grayish-tanish (depending on how the sunlight hit it) came out. drained the oil out of the pan and it was also the same color. took the oil filler neck off of the valve cover and had some "crisco" like material in it. engine does not run hot. one thing i did notice, is that the starboard side manifold gets warmer than the other. i did a compression check on it and it was between 120-132 psi on all cylinders.
one spark plug was alot cleaner than the rest it was the No 1 cylinder.
i have heard of putting some diesel fuel in the oil and a couple of oil changes later to clear up the water.
Any thoughts?
thanks in advance
Ben
Any thoughts?
thanks in advance
Ben
