dominick19m
- Oct 21, 2013
- 2
my 120hp mercruiser 2.5 with hole in the piston in my 67 sterncraft
im wondering since this motor has a solid bottom end with no knocking can i replace the piston head and put the old rod and new or old rod bearings back in and get this thing running without getting the crank serviced or removing the other pistons or should i remove them all and get new bearings? Can i put new bearings in without getting the crank turned.? Im not sure that it matters my crank has zero damage there was no knock and the bearings show little wear i have next to no money for this.. Has anybody ever fixed a piston and put the old rod and bearings back in? Thanks for ur info and opinions
p.s. i did replace water pump and fuel pump to make sure it doesn't happen again..anything else that could cause it and could be done to prevent it in the future plz advise i just bought this boat its a gorgeous old boat for its age i just hope i can give it a few more yrs! i checked the bellows anything else on this boat i should check before hitting the water?
HAHA just found out its a mc-1 outdrive im learning already...!
