keithv3982000
- Oct 18, 2013
- 6
I was driving the boat and I heard a clunk from the rear of the boat and there was blue smoke coming from the back. The boat stopped moving immediately. When I looked the motor itself dropped almost 2 inches, because where the motor was mounted to had rotted and collapsed under the weight.
When I got the boat out of the water and then started the engine there is a grinding noise at the rear of the engine.
I spoke to a friend and he said that I have an issue with the spindles and the alignment of the engine and outdrive.
My question is? it this going to be an expensive fix? Does the motor need to come out?
