mjwellcraft
- Oct 10, 2013
- 4
Hers the short version I took my head off after checking compression 150 psi or close in first 3 and in # 4 had 35psi. Found a
hole in the piston on the inside wall along the edge facing from the front. ok my question is what might cause this and what can I do if there is some small dimples in the wall? Looking to do this very reasonable. Been told a lot of things about this motor and read a lot on here to but need to here from the experts on this motor its a 3.7L 170hp mercruiser? Thanks
