Looking for a bit of advice here. My 1979 Renken with the 165 HP inline 6 has been giving me problems this fall.
We haven't been out this year until fall. The engine would start and idle just fine but stalled as soon as I exited the marina no wake zone and accelerated. I was able to get it restarted and idle back in. I found I had some water in my fuel and added a Moeller fuel water separator. I also found that the O-ring on the fuel cap was rock hard so I added a new O-ring. Pretty sure this was the source of the water.
I ran the boat on the muffs for a while, emptied filter and there was a little water. Took the boat back out and was able to accelerate and get on plane for a couple of minutes, then it stalled. I was able to limp in and when I dumped the filter it was full of water. I decided to replace the anti-siphon valve and fuel line from tank to pump. Also replaced the filter in fuel pump and carb inlet. I used an electric pump to pull the fuel out and this time very little water.
Yesterday we went out and I thought I had the problem solved. She accelerated and ran at cruising speed for about 30 minutes. Then she started to bog again and finally stalled. I emptied the filter and there was just a tiny bit of water in it. But I couldn't get it restarted. She would fire with starting fluid but no fuel was getting to the carb. The fuel filter canister never filled up. I had to be towed in for the first time.
I decided that the fuel pickup may be clogged. So today I emptied the tank with the electric pump. I pulled it all out through the fuel water separator. I had a strong flow of fuel and when the tank was emptied the fuel filter canister was clean fuel, no water.
My question, does this sound like a problem with the Mercruiser mechanical fuel pump? Or should I still look to issues with the tank? I'm now leaning toward the fuel pump, but before I replace it I hoped to get a second opinion. Since the tank emptied so easily through the tank fuel pickup, fuel line and fuel water separator I'm now leaning towards the fuel pump.
Any advice welcome.
Thanks
Jim
Any advice welcome.
Thanks
Jim
