Hi,
I have a Indmar Assault 5.7, same as mercruiser 5.7 basically.
The engine is from 2002, if that would matter.
Last night me and a buddy of mine went out wakeboarding. After about an hour or so of running I was going to pull him out of the water when the motor suddenly died. I gave full power, the engine responded, then quickly lost power and died. Like it was out of gas or something. Though it wasn't.
This might or might not be related to the "actual" problem but I put it out there just in case. And this is the first time my engine has ever failed me except for when I have run it empty on gas.
When I tried to start the engine the starter made a horrible grindning noise together with a terrifying clunking noise. I quickly stopped turning the engine over and we caught a lift in to the dock.
At the dock I decided to give the starter an other try. It did turn the engine over, it made the same terrible noise, even though I quickly stopped running the starter the engine almost came to life and sounded like it fired once or twice and the engine definitely turned over. Once the starter was disengaged and the engine was turning the noise was gone and the engine purred like a cat (as always) if even for half a second.
My own conclusion is that something is messed up with the starter or the flywheel making it sound horrible. Maybe the starter is missing a tooth? However the engine seemed to turn over as usual and therefore it doesn't seem like it has broken terribly inside...
Don't know if this can be related to the engine choking... Maybe it was just a coincidence...
Best Regards,
Mike
Best Regards,
Mike
