Hello,
I am trying to pull the raw water (sea water) pump on a 2005 5.0 Mercruiser Bravo 3 in a Sea Ray Sundeck 240.
I've removed the serpentine belt, idler pulley, and have the pump loose on the threaded stud off the engine block. I have two challenges:
1) the crankshaft pulley appears to be in the way (or perhaps its the Cool Fuel system blocking from the other side) - I can't pull the pump off the stud.
2) the raw water in / out hoses are very challenging to reach.
Any tips? Thanks
Engine Serial #: OW310366
Any tips? Thanks
