SunbirdChaser
- Jun 9, 2013
- 20
Well, I've had the mutt in the water several times. The outdrive goes into reverse at a nice low RPM. However, forward is another issue. Been trying to adjust it several times then, I read something wrong and decided to cut the shift cable. That was wrong and I had to replace it. That's done. As near as I can tell, I set it all up by the book. If I manually push the cable, the boat goes in and out of forward just as it should. That is with the shift cable loose in my hand being pushed and pulled, without the throttle remote. Doing this with the engine running and operating the cable standing over the running engine. I had a good look at all the parts that are visible. When the shifter is placed in fwd, and the stern drive removed, the lever and shaft assembly that is in the lower unit is not facing for and aft. I had to push it with a screw driver to get it to line up both to remove the lower unit and again to reinstall it.
Question? Is it possible that this lever assembly or the shift shafts are twisted. With the shifter in FWD, shouldn't the lower unit slide back on the studs without having to force the shift shafts into a position where the upper and lower portions slide apart?
