Hello guys,
I have an issue that I need your help with please.
I have a 21' 1996 Welcraft with a MerCruiser 5.7 EFI and Alpha one gen 2 drive. I took it out yesterday with the guys and everything was going well for the first hour until a boat jumped infront of me so I had to reverse. I was barely doing Idle then I shifted in reverse.
Everything was fine until I shifted back in drive, it changed normally and I ran on Idle for a min then I kicked it a bit. That's when the boat felt like it lost power. The engine was running fine, but it felt like I just suddenly lost the Prop.
I knew something happened to the outdrive so I parked it right a way. I tried it after a few mins and again, it shifts ok and drives on Idle fine but when I give it more gas, it loses power again even though the engine revs fine.
After a couple of tries, it shifts but doesn't move at all. Al least It feels like it shifts
I brought it back home and thought maybe I have a spun pro so I shifted the gear in drive ( while its off) and turned the prop clock wise. it turnes but it makes a clicking noise and feels like 2 metals rubbing together. Oh, and it doesn't turn counter clock wise.
If the prop is fine, should it move at all when in gear? when I shift in reverse, the prop turns in both directions.
any ideas??
Thank you,
Waldo
any ideas??
Thank you,
Waldo
