My trim will not go up or down but makess a clickin noise, I have made sure connections are clean and replaced both soleoids. Still only clicks.
Ayuh,.... Welcome Aboard,... Sounds like you've narrowed it down to a Bad motor,...
Test wire it directly to 12V,...[/QU
Thanks... I will try that
use a jumper from the battery, touch the blue motor wire , unit goes up. Touch the green motor wire ,unit goes down.
Thanks
Sure sound like you have a bad trim pump motor.Tried the direct wire and got nothing, but a few sparks and very weak, sporatic hum. No outdrive movement. Assuming this means it is the motor.
appreciate all the advice... I did try the hitting it with a hammer thing and still got nothing. A friend of mine suggested it might be air locked...is this a possibility?
