Hello all, this is my first post. I recently aquired an older Grew boat with a Mercruiser inline/straight 6 165hp engine, and a Mercruiser stern drive. I have found through research, and also talking with the local Mercruiser marina, that the serial numbers for both the engine and drive indicate that the year range is 1970-1977 which indicates that my stern drive is a TR2???????? My problem is this. When shifting from reverse into neutral, the engine stalls out. I know that this is due to the cable, and the guy before me put one on it, that last year wouldnt shift at all, and now shifts, but does this in reverse. I googled this and found a lot of info, and people having the same issues, so it most likely is the cable, and I will simply put a new one on it, but I can not find the cable part number, or a breakdown for it. Please help, thanks.
