Just got my 89 sunrunner back from the shop and took it out on the water. The first thing I noticed was that the oil pressure was off the chart (past 80) (Mercruiser 3.0). I called the shop and his answer was "that is a high pressure/flow oil pump we put in because that is what they sent us for replacement. I can change the gauge if you wish". SERIOUSLY? If I normally run between 40 and 55 for pressure and this thing is now over 80 what is it going to do with my motor? I wouldn't think that kind of pressure would be acceptable for my seals. Any responses from you is appreciated.
