1986 mercruiser 3.7 170 hp 3.7 alternator conversion kit
Status
Not open for further replies.
southwest395
I have a mercruiser 3.7 liter 170hp i/o. 4 cylinder with power steering. I'am wanting to switch to a conversion. I see a bunch on eBay and online. Some luck cheap and some look decent. Any recommendations on which one to get? I don't have a lot of room my engine cover a tight fit. And is it better to go to a one wire alternator or three? Ive seen forums where they say one starts charging at 1600 rpms.
a1nowell
Re: 1986 mercruiser 3.7 170 hp 3.7 alternator conversion kit
sw395,
Take a look at the systems offered by Breezeworks. They offer systems with & w/o power steering. I believe all of their systems are 3 wire.
As I understand it a 1 wire system does not start charging until 1200 to 1500 RPM, where a 3 wire starts charging upon start up.
Larry
Ayuh,.... Post yer question, Only Once,....
You posted this in the wrong forum, 'n I moved it,....
Look, 'n you'll see the redirect to yer original thread,....
This 1 is now Closed,....
Status
