1992 4.3 MERCRUISER 1.85GR and a 14 x 21 prop. 256 hours on the motor and it sounds good. Motor sounds great but it seems like it should have more. I'm only seeing a 3800 RPM output at 35 MPH WOT. I'm going to verify the RPM with a tach to make sure I'm reading right. Speedo I'm assuming it right. Old boat may have sticky tach syndrome. Pulled the carb and rebuilt it. Put on a clear 3/8" automotive fuel filter. Changed the fuel hose and left the original style electric fuel pump. Added a high energy ignition coil.
Any suggestions of what else to look at before I change out the fuel filter?
Should I put in a better fuel filter system?
Could it still be fuel delivery or something else?
Plug wires? Plugs?
I could install a fuel pressure gauge but what would the fuel pressure be at WOT?
I'm wondering if there's an easy way to check fuel delivery at WOT to know if I have what I need?
Plug wires? Plugs?
