Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
2005 Mercruiser 5.0 MPI Water Pressure sensor
  • 2005 Mercruiser 5.0 MPI Water Pressure sensor
    My Seloc manual does not show the location of the Water Pressure sensor. Can someone help me out with this. Thanks. Craig
    Re: 2005 Mercruiser 5.0 MPI Water Pressure sensor
    Howdy,
    Welcome aboard!
    First of all, please have a look at the "Adults Only" thread at the top of this forum list.....
    http://forums.iboats.com/mercruiser-...ns-288430.html
    Second, get yourself a copy of the Mercruiser manual for your particular serial engine...... (Most of think Seloc and other manuals are mostly only good for starting your wood stove etc)
    In the mean time, you can have a look at the following manuals link...
    Boatinfo - The library, containing manuals, brochures and other technical documents from the last hundred years!
    Regards,
    Rick
    1987 Four Winns 211 Liberator powered by a 1997 7.4L+Bravo III
    Formerly OMG460 King Kobra powered
    I use xxx oil and have never had a problem........
    This post was created with OpenSuSE x64 Linux!
    • #3
      Hi Craig, On your engine model, the sea water pressure sensor is located on the power steering cooler. Item number 16,
      http://www.mercruiserparts.com/Show_...ing+Components
      OEM Quality Gear Lubes And Greases Available @ iboats.com - BOAT SPECS - FORUM GUIDELINES - Volvo, OMC & Merc Stern Drive Technical Information For DIYers. - OEM VOLVO PARTS POWERED BY iBOATS.COM -
      • #4
        AND it appears to be plated with pure gold-pressed latinum!
        Back to Top
