Jay Curtis
- Mar 7, 2011
- 34
ok the boat is a 1993 Crownline 21' cuddy 5.7 SN OF277191 at least that is what it is suppose to be
PO put an older motor in it 1st question is timing the manual says to ground a purple/whit wire that comes off the front of the distributor i don't have one ?
that section also talks about Knock sensors and a timing control module i dont see either of those
my distributor says thunderbolt 5 is it possible that on this age would not have the spark control?
i am also a little concerned about the knock sensors this motor has small chamber Dart heads so i am a little worried about spark knock if this distributor advances to far
i set my idle timing at 8 and can see that the spark advances when i throttle up but cant tell how far ( dont have a tape or adjustable timing light)
the motor would like a little more advance at idle but not sure a i dare with out knowing what the dist advance does
i more thing i have 2 ground wires in the harness that goes up to the water temp sensors with small lugs on them they are about the size of the wires that go on a coil i cant see any screws near them that would hold them down
any Ideas?
thanks for the help
any Ideas?
thanks for the help
