I am a new registered user on iboats. I recently bought a project 1976 Fiber Form 22.5' Cruiser with a 351W engine and Alpha 1 Mercruiser Leg. The Leg is well painted over covering any serial or model numbers.
I have a single Char Lynn Helm pump hydraulic system steering. The reservoir is a small plastic container with new red Dextron III fluid and mounted about four inches above the Helm pump.
Statically the steering left to right seems okay but with engine running with water muffs, the steering produces a growling/groaning sound that seems to emit from the engine compartment. It is louder than the idling engine, especially on the left and right stops. We have bled the trapped air in the hydraulic actuator located in the engine compartment but the sounds persist.
With the stern in the water and engine idling in gear, I can cycle the steering left and right, but the water seems to dampen the sound a little, is this operational sounds normal?
I really appreciate any troubleshooting techniques I could do before I contact my local repair shop. I am located on the island of Kauai in Hawaii where resources are limited so thank you for any advice or ideas.
