Mercruiser 5.7l V8 Draco topaz starter motor wiring diagram/picture required.. Help!!
Hi peeps.. As the title, I am after a diagram or picture showing the wiring to and from the starter. Cheers, Dan.
LiquidC
Re: Mercruiser 5.7l V8 Draco topaz starter motor wiring diagram/picture required.. He
This is a generic schematic for a starter & elec fuel pump.
This is how we currently have it. I believe the orange wire from the alternator needs to go on the same post as the batt lead. ??
Dan.
achris
More fish than mountain goat
See that black metal tag on the engine block, just above the starter motor? On that will be an engine serial number. If you provide that serial number we can give you the right drawing. Merc have been using the 350 V8 since 1977 and there's been a lot of developments since then, and wiring changes.... That number will enable us to know which particular incarnation of the 350 you have....
Chris....
Hi thanks Chris. I have the engine number jotted down at home. I will post it later this afternoon. Cheers, Dan.
The engine number is... OC764246
Cheers, Dan
achris
Not sure which one you would like, so here's both...
attachment.php
attachment.php
Thank you very much.
