Re: Oil pressure gauge issue
there usually the same thread as the sender. remove the sender and thread in the mech gauge.depending on your exact setup, you may need short nipples coupler fittings to extend up/away/sideways to make the connection.
Installed mechanical gauge, have oil pressure.
Grounded wire to block with key on - no response.
Ran jumper wire from sender to light blue wire on gauge bingo, sender wire is open.
Ran new sender wire. Sender now showing oil pressure. System is now functional. Permanently mounting mechanical gauge in engine compartment as a 2nd check.
Thank you for the help BT Doctur.
