heatz1express
- Jun 23, 2004
- 115
O.K., so first let me say I have always had good luck getting answers on the iboats forums - a good bunch of boaters!
Today, my questions have to do with the engines and drives in my new to me boat. 1986 ChrisCraft Commander 336 with twin 454's and borg/warner transmissions.
first question; Having recently replaced the thermostats in both engines, I noticed that on the Starboard engine there is a third smaller diameter hose coming/going from the housing. It is only maybe 5 or 6 inches long and goes straight back. WHAT IS IT FOR ? and why isn't there one on the port side. Also, when I bought new thermostats the parts guy said that the right thermostats for the year of my engines was 140 degrees. That is what I put in both engines (unless the wrong thermostat was in the package) and the starboard engine still runs around 160 degrees as opposed to the port engine which is running right around 140. What is the correct operating temp. for these motors and why the difference in temps.?
second (and last for now) question; On the portside (which had a new shaftlog installed recently), a moment after I have finished shifting, either from forward or reverse, to neutral there is a squeaking almost high pitched whistle noise that lasts a short time and then stops. A local marine mechanic I spoke with suggested that it is probably the shaft rubbing on the shaftlog packing as it slows to a stop and that it will go away over time. His suggestion makes sense to me since it is a new shaftlog, but the "squeak" seems to be lasting longer after I shift out of gear. Anybody know what it is? Should I be checking my trans. fluid level?
Not making sense to me, since the noise occurs not while shifting, but immediately after I shift to neutral. How can that be trans. ?
