CaptainMak
- Apr 28, 2012
- 294
Someone please clarify this for me.
Installed the Pertronix unit on my 165 HP engine and connected the module wires right to the coil terminals (+ and -).
The boat starts and idles fine when cold. (when hot, it's a different story, again) Then I found out that there is definitely less than 12 Volts going to the coil because of the resistor wire, but the engine still works.
My question is I thought the module wouldn't work if it's not getting the full 12 volts ? Is this killing either it or the coil ?
