Hello folks,
I have a question for the masses. I have an old Merc 1 drive (165) that is having a weird trim / tilt problem. I have power trim and tilt with the 3 goofy button system. Everything works the way it should (sort of). The problem I'm having is while underway, up on plane, the drive creeps up by itself. I have to hit the down button repeatedly to keep it down. This suggests to me a leak obviously. The power pack is not running to cause this malfunction; I can hear it when it runs. There is no external leaking at all. Is there a check valve in the power pack that could be leaking? Anyone experienced this before? Thanks for your input!
