Had acceleration problem, replaced fuel pump, now good, but backfires. Q: does idle mix adj have an effect on backfires?
Electronic ignition, timing good. Thanks.
That spark is before tdc right? Not advanced 8?
Took it out on the bay today, no backfires. But the acceleration/stalls problem remains. Seem with new fuel pump, revs up in neutral ok, but in gear stalls around 1500rpm. Does this sound like it's still a fuel issue?
Replaced all fuel lines and fittings from tank to engine and from fuel pump to carb. All filters changed (in-line, fuel pump, carb). Fuel tank emptied and fresh fuel added.
