Re: Kill switch on invader 165
The one you bought is for an outboard, and they work by grounding out the ignition system. The opposite to what you need.
On the key switch colours. They are not BIA standard colours, so you are going to have to check each wire to determine what it is... Don't worry, it's very easy.
1. Get a test light or multimeter.
2. With the key OFF check the wires until you find one with power. That is the incoming power wire. Make note of its colour. (Most likely the thick red)
3. Turn the key to the RUN position. Find another wire with power on it. That's the ignition wire. Make note of its colour. (most likely the thin red)
4. The other wire left is the start wire.... (most likely the yellow)
I have given you the most likely colours, but you need to check them....
Easy....
BTW. You need to break into the ignition wire, NOT the power wire...
Chris.....
