If the motor is ok otherwise just buy a timing tab from Summit racing or somewhere like that. I put on a fancy cover that it turns out was for an EFI motor and had to get a tab. They only cost a few bucks.
To change the whole timing cover requires removing the motor and pulling the oil pan.
The tab just hangs off two of the timing cover bolts and points where the original one did.
