Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Engine compatablilty 1979 Mercruiser 305 and 1983 Mercruiser 305
  • Engine compatablilty 1979 Mercruiser 305 and 1983 Mercruiser 305
    I need to replace a 1983 Mercruiser 305/5L MCM 228 (serial#6275628) or at least the block. I have a chance to get 1979 Mercruiser 305 898 engine (198HP). Are these engines compatible in terms of the block and should I be able to swap carbrators, manifolds, distributors, etc. Are the sterndrives interchangeable?
    Re: Engine compatablilty 1979 Mercruiser 305 and 1983 Mercruiser 305
    Yes...
    The only physical difference you would encounter between a '79 and '83 engine is the location of the dipstick (oil pan also needs to match the block), if they used the block mounted dipstick. Everything else is interchangeable.
    1976 Rogers Custom Boats 18' "Bonneville" W/ Chevy 454/ Berkeley 12JC
    Care Taker of 1976 Glastron V-184 Crestflight W/ Volvo 170B/280 I.O.
    & 1969 Starcraft W/ 1956 Evinrude 7.5hp Fleetwin.
    • #3
      Originally posted by RogersJetboat454 View Post
      Yes...
      Ayuh,... Agreed,... The dipstick swapped sides in '79, 'n the rear main in '86, so they Should be the Same,...
