Can anyone tell me where the normal water temperature sender is? I am wondering if that is it on the bottom portion of the thermostat housing.
I can't seem to find the water temperature switch, the oil pressure switch, and the drive unit oil level bottle. I am pretty sure that's why I have some wires up there disconnected. Is this a deal breaker for you guys on here? It seems to me that would take out a possible false reading and keep you from being stranded. Your thoughts?
Thanks,
BL
Thanks,
BL
